Project A board is visible in project B what might be the reason for it?
saikiran.padma February 3, 2020
unfortunately user deleted the project A board as it is visible in project B. user thought this might be a technical issue and deleted it. Is there any chance of data restore.
Jack Brickey
You seem to be discussing two issues. Regarding the deletion of the board, you cannot restore it but you can easily recreate it.
What might be the reason for that ?
i mean why other project board is visible on another project
Jack Brickey
The answer depends on the details of what you mean by other project board is visible on the project. A screen shot might help.
for example, if you are saying that you have a board and on that board you are seeing “issues” from another project then that says your board’s filter includes that other project. This can be resolved by editing the filter and removing the inclusive part.
Like saikiran.padma likes this
Ok thank you for your answer
Is there any chance of getting the deleted board back in Jira cloud?
Jack Brickey
If you happen to have a very recent backup then you could do a restore. However, I expect that a restore would likely wipe out more dat than you would get back since all changes post backup would be gone following the restore.
Thank you Jack. It was helpful
saikiran.padma February 23, 2020
Hi @Jack Brickey
can you help me why this case happens?
i mean why the project A board is visible in Project B.
