I've created a Project Automation in Jira, and the final step is: For Current Issue > If Status = Initiate > Transition Issue to "Open".
Initiate >> Open is a valid transition, and it is actually moving tickets to the Open status, but I keep getting messages that the automation failed with message:
"No transitions to specified status could be found for issues (with current status)"
What is possibly going on here? It's correctly transitioning the issue; why does it say it's failing and can't find a transition?
Hey @Sharayah Scott ,
My initial question would be "what is the user that you have set to perform the automation"?
I believe that if you don't have it set as the "Automation for Jira" user and it fails, it will fall back to this user which should have pretty much all permissions.
Also, maybe a screenshot?
Hi Dirk! The user running the automation is a service account we have created for this project, which has full permissions. It serves as the default user for all actions performed by our automations or REST calls. I don't think the user is the problem, as that would return a different error from what I can tell.
