Good morning,
I have a structure with a defined hierarchy (Initiative, Epic, Task, Sub Task) where me ancd other colleagues work everyday.
Is it possible to create a Project Automation in order to assign to all new issues created directly into the structure a specific label?
For example: when I create a new Epic directly into the structure, this has to have a label called "ABC123".
Can you help me?
Amedeo
Hello @Amedeo
It is possible to set a specific label to a newly added issue to a structure the following way:
There is no other functionality in Structure that can automatically set a label on a creation of an issue. Alternatively, there are Effectors which allow to write values to Jira fields, but this feature can be used for setting labels after an issue is already in the structure, and this process is not automatic and it would depend on a user for launching it.
I hope this helps. If you need further assistance with this or if you have any other questions about Structure, please reach out to us directly through our portal: https://tempo-io.atlassian.net/servicedesk/customer/portal/6/group/1051
Best regards,
Stepan Kholodov
Tempo
you can use addons like automation for jira
create a rule that on issue creation in a specific epic, it will change the label
Hi @Alexander Pappert ,
yes, it sounds like you said, but I don't want to specify the epic, because I don't know in advance what kind of Epic will be created, I only know that will be created in that structure.
Any suggestions?
Amedeo
you want the label createddepending on an epic?
whats the rule for the label name?
Try to explain better:
- in this structure all the issues have the same labels
- when I created a new Issues (any types) I would like that the issues created have the same labels referred to that structure
- I don't know in advance the type of issue or the content of the issue created
Hope this can help.
Amedeo
then you must check if on epic creation automation can read your upper structruce of the epic and copy that label into the new created epic
