Project ID and Custom Field ID on next-gen project
Mustafa Bandukda
May 29, 2019
Can you please guide how I can access project ID and custom field ID on next-gen project.
8 votes
Angélica Luz
June 3, 2019
Hi Mustafa,
To get the project and custom field ID, you can use our API.
https://your-domain.atlassian.net/rest/api/3/project
https://your-domain.atlassian.net/rest/api/3/field
You just need to change the "your-domain" and paste on your browser to search.
Then, search for the project name, and it will show the ID:
For the custom field, you can also search by name:
Note that, to make sure it's the correct custom field, check if the project ID matches.
Angélica
Jobin Jose
June 9, 2021
Thank you!
Like Angélica Luz likes this
