Project Import plugins compatibility problem after jira upgrade
Ziad Bakhiet
In order to import a project from a different instance, we upgraded JIRA from version 7.6 to 7.12.3. But after the upgrade I got the following error:
  • The backup project 'BSS OCB' requires custom field named 'Epic Colour' with full key 'com.pyxis.greenhopper.jira:gh-epic-color'. In the current instance of Jira the plugin is at version '7.6.0-DAILY20171103151351', but in the backup it is at version '7.12.0-DAILY20180906101548'.
  • The backup project 'BSS OCB' requires custom field named 'Epic Link' with full key 'com.pyxis.greenhopper.jira:gh-epic-link'. In the current instance of Jira the plugin is at version '7.6.0-DAILY20171103151351', but in the backup it is at version '7.12.0-DAILY20180906101548'.
  • The backup project 'BSS OCB' requires custom field named 'Epic Name' with full key 'com.pyxis.greenhopper.jira:gh-epic-label'. In the current instance of Jira the plugin is at version '7.6.0-DAILY20171103151351', but in the backup it is at version '7.12.0-DAILY20180906101548'.
  • The backup project 'BSS OCB' requires custom field named 'Epic Status' with full key 'com.pyxis.greenhopper.jira:gh-epic-status'. In the current instance of Jira the plugin is at version '7.6.0-DAILY20171103151351', but in the backup it is at version '7.12.0-DAILY20180906101548'.
  • The backup project 'BSS OCB' requires custom field named 'Rank (Obsolete)' with full key 'com.pyxis.greenhopper.jira:gh-global-rank'. In the current instance of Jira the plugin is at version '7.6.0-DAILY20171103151351', but in the backup it is at version '7.12.0-DAILY20180906101548'.
  • The backup project 'BSS OCB' requires custom field named 'Rank' with full key 'com.pyxis.greenhopper.jira:gh-lexo-rank'. In the current instance of Jira the plugin is at version '7.6.0-DAILY20171103151351', but in the backup it is at version '7.12.0-DAILY20180906101548'.
  • The backup project 'BSS OCB' requires custom field named 'Release Version History' with full key 'com.pyxis.greenhopper.jira:greenhopper-releasedmultiversionhistory'. In the current instance of Jira the plugin is at version '7.6.0-DAILY20171103151351', but in the backup it is at version '7.12.0-DAILY20180906101548'.
  • The backup project 'BSS OCB' requires custom field named 'Sprint' with full key 'com.pyxis.greenhopper.jira:gh-sprint'. In the current instance of Jira the plugin is at version '7.6.0-DAILY20171103151351', but in the backup it is at version '7.12.0-DAILY20180906101548'.
How can i solve this plugin compatibility error ?
Andy Heinzer
August 6, 2019
Hi Ziad,
I understand that you have recently upgraded your Jira from a 7.6 to a 7.12 version, in order to import a project from a separate 7.12 backup file.
However the error messages you see here would tend to indicate that your upgrade has not been completed yet, at least not for Jira Software.  It's possible that perhaps you have updated Jira Core to this 7.12 version, but Jira Software will operate like a plugin, and in turn when you upgrade Jira Core first, you then have to update Jira Software to allow it to update your data.
On your destination Jira site, try going to the Gear Icon -> Applications -> Versions and Licenses.  I'd be interested to see what version of Jira Software is reported here and if there are any error messages on this page.   If my suspicious is correct, and Jira Core has already been upgraded, then you can just update Jira Software directly on this page without having to restart Jira.
If this doesn't help, then I'd be interested to see if you can restart Jira and then if we could see what a startup looks like in your $JIRAHOME/log/atlassian-jira.log This file can tell us more about the specific versions of plugins that are being loaded by Jira at startup time.   If the 7.12.x Jira Software plugin is not loading for some reason, it too could explain this error, and the logs should give us some clues as to how we can address this problem.
Andy
Ziad Bakhiet
Thank you so much Andy for your answer, I had to upload the jira software obr file once again to my apps.
Quinton Lephoto February 18, 2022
Hi @Ziad Bakhiet
How did you get hold of the jira softare obr file?
do you mind sharing the link maybe
++ @Andy Heinzer
Can you please assist with supplying the jira software obr file that Ziad used to fix this error
Andy Heinzer
February 18, 2022
@Quinton Lephoto In order to install Jira Software from an OBR file as mentioned above, the Jira Core has to be in the matching version number first.  If that's the case, then you can download the corresponding OBR found on https://marketplace.atlassian.com/apps/1213607/jira-software/version-history
But for most users that are looking to upgrade, using the installer packages found over in https://www.atlassian.com/software/jira/update will update both Core and Software at the same time.
I hope that helps.
Andy
