When trying to use the "work management", "project management" template - the button "use template" is greyed out with this message "Your Jira admin is responsible for creating new projects using this template. Contact them for assistance"
Can I get this on a trial basis or permanently as one of our available templates? It would be the one that works best for our team.
Is the error message indicates your question needs to go to your admin. The community here doesn’t have the ability to grant that permission. Note the option is either on or off there isn’t a trial basis. If you aren’t going to be creating projects often I would definitely have your admin deal with this as there could be quite a bit involved in building projects. One consideration is to have your admin open up TMP projects this will allow the team to build whatever projects they need in a more simplified environment.
Thank you, I will reach out to our admin.
