Hi community.
2 administrators are members of the relevant group, me and one more user.
I removed the user from the group and asked her to check if is able to edit a workflow.
I was told that can edit the workflow.
Since i removed her, should still be able to edit the flow?
Thank you.
is she a project admin still? if so, and the workflow isn't shared across projects, she will be able to edit.
No, she is not and the workflow is shared only by the specific project.
