Cannot see Workflows in Project Settings so cannot set a default project workflow.
I am Adminstrator for the project. How to set a Project Workflow?
I am trying to follow the Atlassian help.
you are on a Next-gen project which does not support or require Workflows at least in the classic sense.
NG workflows (except for Service Desk projects) are created solely (currently) via the board. The workflow is simple in that issues are intended to move left to right but do not require sequential movement. There isn’t a workflow that you view and edit like in Classic projects.
Hi @Paul Wade ,
Is the complete workflows page missing or only the option to change the workflow?
The Jira Administrator can configure if they will give you the rights to edit the workflow or not. So maybe, it is not enough if you are project Administrator but you need to be Jira Administrator.
OK I checked and I am jira-administrator as well.
This is the screen where I am expecting to see Workflows so that I can assign a Project Workflow.
In the list of Workflows Schemes I see some but all in the Inactive list. The Active list is empty.
OK I checked and I am jira-administrator as well. This is the screen where I am expecting to see Workflows so that I can assign a Project Workflow. In the list of Workflows Schemes I see some but all in the Inactive list. The Active list is empty.
yeah, i'm having this same issue right now...
@Bhavani , what exact issue are you having? Are you using Team Managed Project? Are you the project admin?
Yes I am the project admin, But I am not able to find the Workflow option under the project settings.
I am new to JIRA, So Can you tell me how to check if i am working on Team managed project or not?
Thank you I got it,
Now I also need to know how to convert Team managed projects to company managed projects.
Correct me if I am wrong, In the company managed project I will be able to get the workflow option under project settings right!
Correct. However, you have workflows by issuetype in TMP now as well. In the Board view click on ellipses in top right
