Project Templates
amy_p_teachingstrategies_com March 5, 2024
Our technology department consists of many product teams, each operating within the Safe Agile SDLC framework. Some teams lean more towards Scrum, while others favor Kanban. Across the company, we have numerous Jira projects for various organizations. However, the software development teams primarily use one Jira project, leading to an excess of customized fields and labels.
As a result, we've overcomplicated the process of resolving issues and planning resource capacity. Consequently, the built-in Jira reports are no longer accurate due to all the custom fields and data.
I plan to create a test Jira project to identify the minimal number of items needed for teams to work issues from start to finish in the SDLC process. This will also allow us to confidently use the built-in Jira reports.
Could you recommend a suitable project template type?
Thank you so much!
John Funk
Hi Amy - Welcome to the Atlassian Community!
It really doesn't matter which template you use because you are most likely going to modify it anyway. Just be sure to use a Jira Software Company-managed project.
amy_p_teachingstrategies_com March 6, 2024
Thank you so much, John! we are hoping to stay close to a standard version template where the built-in reports like (Sprint Report | Burndown Chart | Burnup Chart | Velocity Chart | Epic Burndown Report) still work and accurately reflect the results.
Like John Funk likes this
John Funk
They will still work even if you make some modifications to the template.
Lukas Nicolai_Seibert
Hey @amy_p_teachingstrategies_com I am Product Marketing Manager at Seibert Media, and I think our Templating.app could also be a good solution for you.
With our feature, administrators can create Jira project templates with pre-defined schemes. After setup, non-admins can create projects based on templates with available schemes. This way, you may be able to avoid random custom fields and data in the future.
If you are interested in discussing your use case, we would love to jump on a call with you.
amy_p_teachingstrategies_com May 15, 2024
Thank you, Lukas! I will review this feature to see if it meets our needs. I may take you up on reviewing this feature further on a call too. Thanks again!
Like Lukas Nicolai_Seibert likes this
