Hi guys,
I've spent way too many hours cracking my head around this and can figure it out so time to ask for help :D
OBJECTIVE
Grant clients access to their Confluence Space and Jira projects only so they can contribute, document and sign off on requirements and tickets.
STEPS TAKEN
PROBLEM
When I log in to Jira as that user the Projects List display projects where user is not assigned to in any way.
Now, I know what you may be thinking "The user may be getting access to these projects through another groups or role or whatever"... but here is the strangest things:
- If I remove the Project Role permission for clients to Browse projects then I do not see ANY project.
- If I grant to permission to Browse Projects to just that user then they see ALL projects in our instance.
- Some of the project displayed to this user under current setup do not even have a Project Role assigned to them:
If I go to the "View Usage for Project Role: Client" on Jira Settings is where I think the issues is:
- I can see projects listed there with a number higher than 0 (view). However when I click on view there is no Project Roles assigned to them!!
Is this a bug? and if so why just in some random projects? How to resolve?
Hello Didier,
it could be that other permission schemes make use of Application access for project permissions.
Other default access groups (screenshot only shows group Clients) could have been granted to the projects when they were created.
Have you tried the Permission helper?
Hi @Johan Soetens _Dumblefy_ thanks for the answers.
As far as I understand it a project can only have ONE permission scheme assign to them right?
So following that logic and with the provided rules of the assigned permission scheme there should not be any effect form other system schemes to these projects.... (plus all out project share the same Permission Scheme)
This may make a bit of sense and happy to explore this further.... but... is there a way to change these? Haven't find anywhere on Project permission around this..
Further more after doing some debugging using the Permission helper (pretty good tool I was not aware of thanks).
What I see is "User XXXX is a member of the Client project role"... However, that specific Project has no assignation on Project Roles under 'People' tab...
So, unless I completely misunderstood the usage of Project Role, isn't this a bug where is a user is assigned to that Role (in another project) it then gets permission to ANY project that has a user assigned to that Role (even if not the same user)?
My understanding is that a user assign to a Role in a project only gets permissions of that Role in the specific project he is setup and not others...
Hi Didier,
if I understood correctly you created a group clients and project role Client.
This project role was then used in your permission scheme which is used in most to all projects.
The result of permission helper is indicative that you haven't granted the group clients to the project role in a project.
The default members for your Client project role should include group clients.
Even when this group clients is added, the caveat here is that this would only have affected newly created projects.
All existing projects will need to you to add group clients to the project role (Project settings > People).
Hi @Johan Soetens _Dumblefy_ seems we deviated a bit form the actual issue... let try to summarise this better:
Group 'Clients' only used to group licenses in our instance. There is no mentions or usage of this under our Permission Scheme. Here we add ALL our clients accounts...
Project Role 'Clients' is the one we have associated to our Permission Scheme to be used.
- If we associate the group to a Role then ALL clients would get access to that project which is not what we want.
- Instead we simply assign specific clients users to that role for the specific project so the gain whatever permission we have defined on the Permission Scheme.
Again, this is all working as expected except for some random projects showing to our clients where there is nor Project Rola allocation at all.
The permission helper for those random project says the user is assigned to the 'Clients' Project Role which is not true... that is where things are wrong.
If I change the Permission Scheme to remove Browse Project to the 'Client' Project Role then use does not see ANY project which confirms the problem is just on that Project Role allocation right?
