Hi Everyone,
I'd import a project from a Jira to another. When the backup.xml started parsing suddenly I got the following error message:
There was an unexpected problem processing the backup XML file at.... Timestamp format must be yyyy-mm-dd hh:mm:ss[.fffffffff]
The 2 Jira's time and date format are identical: actually the source Jira is our PROD and the target is our TEST instance. Both are of version 7.5.2
The only thing I did that I edited the entities.xml because of this error:
So I only changed a few customfieldconfig IDs! No rows have been moved or extended!
Then I saved the entities.xml and zipped and wanted to import into the target Jira. Then I got this error.
The real problem is that the error message nor atlassian-jira.log shows the exact place of the problem.
Is there any way to detect where is the problem in the entities.xml?
Thank you in advance for the hints!
kindly have a look at this KB:
Hello Alexey,
thank you for the fast response!
Yes, I read this page already and my concern is that how can I find the problematic row in the entities.xml?
