Project key
HaRsHaS' V July 23, 2020
Does changing Project key in a newly created project/empty project affect anything as mentioned in the documentation
https://confluence.atlassian.com/adminjiraserver/editing-a-project-key-938847080.html
Please advice
Sachin
July 23, 2020
Hello @HaRsHaS' V , if it’s an empty project you can just create a new project using “shared configuration” option that way you can chose the project key you want and not lose any project configuration.
@Sachin
Thanks for the reply. I have created the project using shared configuration-however, I had to change the key and I changed it. It went on a project re-index. I was wondering if any links for external applications or anything would be affected.
Note: Its a completely new project and no issues have been updated in it yet.
Sachin
July 23, 2020
There won’t be any issue regards to application links Harsha. Just make sure you update your saved filters/webhooks with new project name or key.
@Sachin ..Okay sounds great!.
There are no filters/ or webhooks related to the project currently. As mentioned it is a fresh project. is there anything I am missing with reference to filters or webhooks or anything else?
Sachin
July 23, 2020
I can’t think of anything Harsha! Just make sure you archive the old project so no one uses it (associate it to a read-only permission) scheme or just delete it.
Great! Thanks.. there is no old Project associated with it. I just made the key change to the newly created project. I was worried if there will be any issues in future with filter, links and another others. As per this convo, i dont think they should be any
Thanks!
