Hello All
We would like to configure a field at Project-level like ( Like Project URL, Project Lead or project description.
Not a custom field It should be a project-level field.
Hi, have you checked out ProFields? This should be able to help as you can’t do it with Jira by itself as far as I know.
Thanks. You are right but it is a paid Plugin and why should we go with a Paid Third partu plugin and why can't Atlassian introduce this long time request which is pending for years https://jira.atlassian.com/browse/JRA-1991
Atlassian generally do not build stuff their partners app suppliers have built until it becomes something that they see as being important as part of the core product. I suspect "project fields" are something that's not seen as important as a lot of other stuff in their backlog, and is also easily solved with ProFields. So it's a very low priority for them.
