How to find dependent projects when an issue is connected with issue in another project , is there any Query, we need to run?
Hi @Srijan Srivastava and welcome to the community,
What exactly do you mean by "dependent" project? Do you mean the project in which the linked issue is located?
Best
Stefan
Each project has its own key (shortcut). So if you link the issue you can see the issue key telling you in which project the issue is located. If the project is not clear at that point you could then open the projects drop down in the main menu panel and click "View all projects" where the keys of all projects are shown.
Trying to understand the use case:
When exactly, where and who would need to have this information?
Best
Stefan
