Property Key in workflow how do they work
Jon
are there any articles on how this works? I have trying to do some things in the workflow that cant be done with validator or conditions.
thanks
Alexey Matveev
November 16, 2018
Here is the best article  I have ever seen about workflow properties:
https://www.j-tricks.com/tutorials/permissions-based-on-workflow-status
Jon
thanks.
I was looking at this article aand it gives a good framework how this works but wondering if you know how to perform the denial of linking (epic link) a issue to an epic in a particular status.
I tried these two but doesn't seem to work.
jira.permission.epiclink.denieddenied
jira.permission.link.denied
Alexey Matveev
November 19, 2018
Try like this:
jira.permission.link.group.1=some-group-one
You can read more info here:
https://community.atlassian.com/t5/Jira-questions/Can-we-disable-linking-issues-to-an-Issue-when-it-is-closed/qaq-p/324525
Jon
HI Alexey,
if I do this like you put above  do I do "allow" instead of "deny"? An basically there is no one in this group so its the same as a deny property?
And when I make this group can it be the default group that jira gives or do I have to make a custom group name? I would make these groups in the permissions under the project right?
thanks again
Alexey Matveev
November 19, 2018
Not all properties have the allow option. I guess, the same thing with the link property. Yes, if no one is in a group, then it is basically the same as a deny property.
I can be a default group. You make this group in the User Management menu.
Jon
got it. so I made a group, called "Group". How should I construct this property?
so should it be constructed like this or do I have to add other characters? this would basically allow only those in the "group" to change links on epics that are in the closed status and since no one is in the group no one would be able to do it.
property key: jira.permission.link.group=group
property value: allow
Alexey Matveev
November 20, 2018
It should be :
jira.permission.link.group.1=group
Like Krishnam2330 likes this
Jon
it doesn't work, should it be like this, given that the group is called " group" and there is no one is in it? And it would be allow?
Alexey Matveev
November 20, 2018
property key = jira.permission.link.group.1
property value = group
Jon
it works for regular links but it doesn't work to deny epic links. I have this property on the epic itself to prevent regular issues from being linked to it. how would I reword the property?
Jon
hi Alexey,
do you know if there is a way to make this for epic link or  should links be the same as epic links.
another thing I was wondering is how would you go about changing the permission to deny or allow users from a particular field only. is that possible?
Thanks again.
Alexey Matveev
November 21, 2018
I do not think, there is such a permission.
Jon
you mean there is no permission for epic links or for field specific premissions?
Alexey Matveev
November 21, 2018
I am sure that there is no field specific permissions. Also there is no separate permission for epic links.
Deleted user August 25, 2020
Hi @Jon & @Alexey Matveev
Were you able to find a solution to hide Epic links using Workflow Properties ?
I have a similar requirement and have not found a solution yet.
Regards
Abrar
Daniel Wong
November 16, 2018
Hi Jon,
Are you referring to workflow properties? If so, you can go to this KB for more information - https://confluence.atlassian.com/adminjiracloud/workflow-properties-776636709.html
What sort of workflow functions are you trying to do that a validator / condition can't do?
Jon
Hi Daniel, I’m trying to restrict the issue from being certain fields (but not all fields) including the epic it’s linked to if it is in the paid status.
