Put more than 1 Project into Roadmap
Karyna Alieksieieva September 7, 2020
Hey!
Is it possible to put together more that 1 project (for example, 2-3 different Jira projects) with epics into the Roadmap representation (that is in BETA) ?
Thank you!
Darrel Jackson
I believe the Advanced Roadmaps feature in Jira Premium supports this. The Basic Roadmaps that comes with Jira Software only supports single project. Discalimer: I've not used Jira Premium - just going by the feature list.
Samuel Justus
tried the free trial specifically for this and it's not working :/
Like Abir Stolov likes this
Jack Brickey
You tried Premium? Muilt-project roadmap support is part of premium but not standard. You basically create a Plan to achieve this.
Vincent Grajek August 16, 2021
Hi @Jack Brickey , I've just tested with Premium but it does not fix the problem. If you have more than 1 project in your board filter, you will still get the message : "Your roadmap isn't available because the board filter contains multiple projects."
As you said, the workaround is to create a Plan and sharred teams, but it is not at all what we expected, so if someone has a solution, i would appreciate the support ;)
More information in the ticket : JSWCLOUD-20703
Jack Brickey
I have not attempted this but given that Roadmap is at a Board level and a Board can represent issues from multiple projects I would assume this would be possible. Easy enough to to test it out.
Hey! Thanks for the answer!
It gave me:
Roadmaps are designed for single projects
Your roadmap isn't available because the board filter contains multiple projects. To use your roadmap, adjust the board filter to include issues from Project XXX only.
I'm using Classic Jira
It seems that it is not possible :(
Jack Brickey
Well then there is the answer. Thanks for testing it out.
Ste Wright
Hi @Karyna Alieksieieva
There is a suggestion to have multiple projects on one Roadmap you can vote/follow - see: JSWCLOUD-20703
Ste
Like Stuart Capel - London likes this
