Query not working for resolved issues
Michelle Chu
Hello! I am trying to pull issues resolved within the last 30 days. I have used:
resolved > -30d
resolutiondate >= -30
I am getting no issues, even though I know that isn't true. Any ideas why?
John Funk
Hi Michelle - I see no problem with your query. I ran it myself and see issues.
Maybe try adding a project in the front of it:
Project = ABC and resolved > -30d
Michelle Chu
Yes, I am already doing that.
Like Dave Liao likes this
John Funk
Run a query for just Project = ABC and statuscategory != Done
and see how many issues there are
Then look at the status and Resolved today to see when they were done
Like Carmen Valdés Téllez likes this
John Funk
@Michelle Chu  - Any update here?
Michelle Chu
Got the query to work, thanks!
Like # people like this
Payne
May 26, 2021
Are you sure that you have resolved issues in your instance? Occasionally when folks set up workflows, they'll conclude with a Closed status or something similar, but unless there is a Resolution on an issue, it is not resolved.
Dave Liao
@Michelle Chu - If what Payne is suggesting is true (it happens*), considering using this JQL as a rough workaround:
project = PROJECTID and status changed to "DONESTATUS" BEFORE -30d
  • replace PROJECTID with the project key you want to query, and
  • DONESTATUS with the name of your "Done" status. It might be "Done", or whatever your admin/s have configured.
* I would check with your admins to ensure your project workflows set (or ask the user for) a Resolution field value when closing tickets.
