Hello! I am trying to pull issues resolved within the last 30 days. I have used:
resolved > -30d
resolutiondate >= -30
I am getting no issues, even though I know that isn't true. Any ideas why?
Hi Michelle - I see no problem with your query. I ran it myself and see issues.
Maybe try adding a project in the front of it:
Project = ABC and resolved > -30d
Run a query for just Project = ABC and statuscategory != Done
and see how many issues there are
Then look at the status and Resolved today to see when they were done
Are you sure that you have resolved issues in your instance? Occasionally when folks set up workflows, they'll conclude with a Closed status or something similar, but unless there is a Resolution on an issue, it is not resolved.
@Michelle Chu - If what Payne is suggesting is true (it happens*), considering using this JQL as a rough workaround:
project = PROJECTID and status changed to "DONESTATUS" BEFORE -30d
* I would check with your admins to ensure your project workflows set (or ask the user for) a Resolution field value when closing tickets.
