For example if we have open->In Progress->In Review->Closed statuses in a work flow. Now i want to have different colors for different statuses. For example for open->black In progress->Blue In Review-> Red like that i want. Is that possible in jira? If so how can i do that.
Hi @Aravind Koushik Gobburu By default changing the status colors apart from the default Grey, Yellow and Green is not possible, but you can use the below marketplace plugin to achieve the same,
https://marketplace.atlassian.com/apps/15237/jira-status-color?tab=overview&hosting=server
Go through the plugin documentation for more details :
https://bitbucket.org/brightsoftapps/status-color-for-jira/wiki/Home
@Aravind Koushik Gobburu By default Jira does not have any option to add custom colors for statues, either using plugin you can achieve this or develop something similar using the Atlassian library. the similar what plugin vendor has done.
