I am looking to create 2 custom fields which would be the following:
Estimate at Completion = Remaining Estimate + Time Spent/Logged
Variance = Estimate at Completion - Original Estimate
I've previously done this using JMCF at a previous employer but now trying to see if it can be done using automation?
Hi @rob.jeal
You can use mathematical expressions in automation.
In formation on who to use them can be found here:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-math-expressions/
Thanks @Marc - Devoteam . I am getting success in the audit log but then the field is still showing None, do you have any idea why this might be sorry? This is what I have inputted in the "edit issues" section of the automation. The field it is populating is a custom number field "estimate at completion"
{{#=}}{{issue.fields.timetracking.remaining estimate.plus(issue.fields.timetracking.timeSpent)}}{{/}}
Hi @rob.jeal
I see there is a slight mistake in you mathematical expression.
I think it should be like this:
{{#=}}{{issue.fields.timetracking.remaining estimate}} +{{(issue.fields.timetracking.timeSpent)}}{{/}}
Thanks again @Marc - Devoteam . I tried your expression and got the following in audit - Failed to get value for (issue.fields.timetracking.timeSpent): {{#=}}{{issue.fields.timetracking.remaining estimate}} +{{(issue.fields.timetracking.timeSpent)}}{{/}}
I removed the 2 normal brackets from the timeSpent part of the expression and am now getting the following:
Too many numbers or variables: +0m
I am guessing this relates to the timeSpent field as I only changed the remaining estimate, whereas when I added 2hrs to time spent I got the same "too many numbers or variables" message but "+2h" instead of "+0m" .
It is a custom "number" field I am trying to populate as couldn't find a more appropriate field type.
Hi @rob.jeal
I think the issue is that math functions rely on number fields, the time fields in Jira are probably not recognised as number fields in Jira.
So we might think differently.
{{#=}}{{issue.timetracking.remainingestimateSeconds.divide(3600).round}} + {{issue.fields.timetracking.timeSpentSeconds.divide(3600).round}}{{/}}
That's great @Marc - Devoteam thank you that has worked now.. I was hoping the result could be to 2 decimals (currently no decimals). I've removed the .round to see if that helps but still the result has no decimals.. Sorry last hurdle hopefully and then we're good!!
