Remind assignee after 24 hrs of inactivity using Script runner
Anil
Hi Team,
Is it possible to send notification to Assignee after 24 hrs of inactivity of a ticket which is in particular status using script runner?
Thanks in Advance
Anil
2 accepted
Ravi Sagar _Sparxsys_
February 15, 2021
Hi @Anil
You can create an escalation service under jobs to achieve that but adding a comment on the issue or create a custom scheduled job to send an email. You can find sample code here: https://library.adaptavist.com/entity/send-custom-email
I hope it helps.
Ravi
Anil
Hi @Ravi Sagar _Sparxsys_ Thanks for your quick response.
Actual requirement is, If issue status is in "In progress" and assignee should be notified if no activity is on that specific issue for more than 24 hrs.
Kian Stack Mumo Systems
@Anil
Check out using Escalation services with Scriptrunner. That should get you started!
Kian
Anil
Hi @Kian Stack Mumo Systems Thanks for your quick response.
I tried Escalation service. But, the requirement is "Status shouldn't change" and "Assignee should be notified" about the issue. Which should be similar to SLA in service desk.
BTW we are on Data center and have only ScriptRunner.
@Anil, what exactly the problem with using escalation services, if you don't mind explaining? Using Escalation services try doing the following:
To set a comment, you can use the code
issueInputParameters.setComment('Write your comment here')
Anil
That worked. Thanks Kian
