Hi There,
How do I remove my project (Luna Change and Release) from the CR: Kanban Issue Type Screen Scheme shown in the screen shot, I can't see where I can simply remove my project from the screen scheme. Edit doesn't give the option, also under configure its not apparent where to remove my project see second screenshot as well.
In order to remove the project from that issue type screen scheme, go to your project settings and change which screen scheme your project is associated with.
If you need an overview of how all the schemes belong together, I recommend taking a look at Project screens, schemes and fields
In my case the project is deleted. There are no project settings in that case, just a dead reference. What then? Using Jira Cloud.
@Mikael SandbergI have a similar problem, my project is deleted but it is still associated with the issue type screen scheme. So I don't have access to the project settings to remove the association. Is there any way around this?
UPDATE: I just restored the deleted project from the trash which should solve my issue.
