Hello. I've set up structure from certain Jira project, so I believe the issues in that very structure are formed by SQL query, like on screenshot below.
The problem is, that when I try to delete an issue from the structure, I cannot do that - I get the error saying that an issue can't be removed from SQL query.
Is there any way I can delete some issues from such structure other than creating new custom structure and adding all issues manually?
Hello Ivan,
Dmitrii with ALM Works here.
If you are using generators to add your issues, it will not be possible to remove a specific task from its results (generated content), unless:
In case the options that I described won't work for you, could you please raise a support request for this by emailing us via support@almworks.com? We will want to review some additional configuration options with you, since from your screenshot it is clear that you also use Manual Adjustments, which suggests that your specific configuration may need a closer look.
Dmitrii Kuzmin
ALM Works
Hello.
Yes, I decided to just filter out what I don't need, thank you.
