Reporter not receiving issue created notification
Jan Evetts November 28, 2013
I have a jira-user who is not receiving an issue created notification when he reports an issue, I can see a notification queued in mail queue but the user receives no notification. He does get an issue updated notification.
Thanks.
Jobin Kuruvilla [Adaptavist]
November 28, 2013
Check if his profile has "Notify for own changes" unchecked. If so, he won't get notifications for issues he created.
RambanamP
November 29, 2013
@Jobin, user able to get issue update notifications that means he selected notify me as "Notify for own changes", is am correct??
November 29, 2013
Depends. What if the update is done by another user? ;)
Ben Phillips
September 5, 2019
I have the same issue. The issue is not with "own changes" either. The Reporter is listed to get notifications on all of the notification scheme operations.
Steps:
  • 2 completely unique user accounts: Agent (fulfiller) and Customer (Reporter, member of a customer Org).
  • Agent opens a request for a Reporter.
  • Reporter does not get any notification.
  • Agent leaves updates (comments) or even state changes to the request
I can only get the reporter to receive notifications if the reporter opens the request themselves
Need help. Thanks
Decupere & Partners IT Team October 18, 2019
I'm experiencing the exact same issue. Does anyone have a solution for that?
Trena Norcia
Is there an answer to this issue?
Johnny Lau September 8, 2020
It happens to my system too. Reporter will only receive notification if the ticket is raised via customer portal.
In any case, if an agent tried to raise ticket on behalf of reporter via agent access/screen; Reporter will NOT get any notifications.
Grace Rago
October 19, 2020
@Johnny Lau  think your'e missing to set the 'Customer Request Type' value when creating the issue directly in the application. This field is usually set when created in the customer portal . For JSD, this field is required for customers to receive notifications.
See detailed explanation here https://community.atlassian.com/t5/Jira-questions/Reporter-does-not-recieve-notifications-for-issues-created-on/qaq-p/773661
Pavandeep Ruprah
May 14, 2019
Hi do we have a solution for this issue as we are experiencing the same.
Hjalti Glúmsson August 30, 2019
I have this situation for users who only have customer access, but not Jira Software access. They can be the reporter and mentioned in a comment, but they don't get notified since their only access is the customer access.
Shell D August 7, 2018
Any solutions for this, we are having the same problem, but only with projects using the default notification scheme.
Vera Henrichs
April 9, 2014
Here the same problem. Tried the check/uncheck but doesn;'t seem to mind.
Daniel Mazurkiewicz
January 14, 2014
I have the same problem. Notification helper confirms receives notifications for the 'Issue Created' event but email doesn't come.
RambanamP
November 29, 2013
is reporter configured for issue created event in notification scheme?
https://confluence.atlassian.com/display/JIRA/Creating+a+Notification+Scheme
and also you can check with notification helper
