Bonjour,
j'aimerais faire la requête suivante dans Jira :
Obtenir tous les Jiras du projet X pour lesquels :
- il existe une sous-tâche de statut 'terminé' dont la description contient le mot 'report'
ET
- il existe une sous-tâche de statut non 'terminé' dont la description contient le mot 'construction'
Pouvez-vous m'aider svp ?
Merci
FB
Hi @Florence BELHENNICHE -- Welcome to the Atlassian Community!
If I understand your request correctly, you want to:
Return all issues in project <X>
(Which have a sub-task where status IN (Completed) AND Description ~ "report")
OR
(Which have a sub-task where status NOT IN (Completed) AND Description ~ "construction")
If that is correct, you cannot do that with out-of-the-box Jira. The JQL isn't a real SQL, so you would need a marketplace scripting add-in to do this. Perhaps something like ScriptRunner.
If you just need to do this once, as a work-around you could export the issues from Project <X> to a spreadsheet and perform the query using formulas there.
Best regards,
Bonjour Bill,
ma requête est la suivante :
AND
Merci pour votre réponse. Je vais me renseigner sur l'outil ScriptRunner auprès de mon entreprise.
Cordialement,
F.B.
Thanks for clarifying your request; I misunderstood what you were trying to accomplish and so substituted the OR clause.
I hope that you have a happy new year!
__Bill
