Hi Guys.
i am doing configuration of Zephyr plugin in jenkins and stuck on Zephyr Base URL, i don't have idea from where to get that information.
Based on the Zephyr documentation, i think it might be
https://prod-api.zephyr4jiracloud.com/connect
reference:
Hi Ahsan! Have you been following Zephyr's documentation? Zephyr is supported by a third party developer so if you still have questions after that, my recommendation would be to contact Zephyr Support direclty so they can guide you.
Once you get a response from them, you could share the answer here so other members of the Community can also benefit from it :)
Ana
Thanks @Ana,
Btw i have done the complete configuration and got the desire results as well.
regarding benefits, yes i am available for help :)
Hi Ahsan,
I am also getting same error as observed by you. Can you please let me know what you do to eliminate this error
Hi ahsan ,
can you please help ? what did yo do to get the zephyr base url ?
Thanks & Regards
@ahsanakhtar any chance you could help out here?
