I cannot go thru reset link on resetting the password
Given: I received the email from server with a link
When: I clicked on the link
Then: It will appear an error with this error:
java.lang.NullPointerException: ConstantTimeComparison.isEqual does not accept null values.
Hi Hsiang,
I've checked the attachment and the stack trace us shown traces of the add-on BigPicture:
at.softwareplant.ppm.structureint.jiraserver.event.PluginIssueLinkListener.doFilter(PluginIssueLinkListener.java:72)
Would it be possible to disable the add-on or use the safe mode to test if the link will work?
- Disabling or enabling all apps (using Safe Mode)
Please, give a try and let us know how it goes.
Angélica
It's still not working. I tried doing it in safe mode.
Here's the follow complete details.
Hi Hsiang,
Are there other users facing this issue or it's only one user?
Is this link for resetting password for internal user or customer?
Is this issue currently active on the instance?
Angélica
I have exactly the same issue on my side (Jira DC 7.5.4) for a specific user, here is the stack trace I get :
at com.atlassian.security.utils.ConstantTimeComparison.isEqual(ConstantTimeComparison.java:31) [atlassian-secure-utils-3.2.3.jar:?]
at com.atlassian.security.utils.ConstantTimeComparison.isEqual(ConstantTimeComparison.java:47) [atlassian-secure-utils-3.2.3.jar:?]
at com.atlassian.jira.user.util.PasswordResetTokenBuilder.validateToken(PasswordResetTokenBuilder.java:81) [classes/:?]
at com.atlassian.jira.user.util.UserUtilImpl.validatePasswordResetToken(UserUtilImpl.java:408) [classes/:?]
at com.atlassian.jira.web.action.user.ResetPassword.validateUserAndToken(ResetPassword.java:105) [classes/:?]
at com.atlassian.jira.web.action.user.ResetPassword.doDefault(ResetPassword.java:62)
How can we fix that ?
