Hello Together,
Is it possible to restrict a Move Operation from One Issue Type to a particular Issue Type ?
For Ex., If a user has permission to move a issue from one issue type to another, but here we want that the user should not move an issue type to a particular issue type.
Thanks in advance. Any suggestion would be very helpful.
Hi @Tanu Ranjan Bharadwaj this issue is fixed in this discussion :- https://community.atlassian.com/t5/Jira-Questions/Block-Move-issue-only-for-specific-issue-types/qaq-p/796459
Hello @Vikrant Yadav ,
The solution mentioned here is not what I am looking for.
I want that when the user make the Move Operation from one particular issue type then he/she would not be able to choose one particular issue type.
Do you have any answer for that ?
Thanks & Best Regards,
