Restricting export of issues from some Jira Projects
Kasturee
Is it possible to restrict the exporting of issues from some Jira Projects? You can search for the issues for that project but must not be able to export it via the Export functionality.
Mirek
Hmm.. Not really sure why you would like to block that functionality. By doing this you do not protect any data since someone could still get it manually one by one .. If someone like to use Excel as issue view he should be allowed to do so..
However if from some reason you would really like to block this, I think it is possible as many other things but requires some customization. Maybe by using JS modification or when using Apache you can block a specific request (URL) .. That what came to my mind quickly.
Kasturee
Thanks. Yes totally agree. Lucky this is not a requirement  any more
