I have set up restrictions for issue types, but these restrictions are only being applied to new issues. How can I apply these restrictions to existing issues as well? I attempted to write a script in ScriptRunner to address this, but I am unsure of the field ID required.
Cheers
Welcome to the community @Maciej Oczoś
These restrictions will only apply for the new created issues. The restrictions do not apply to the existing issues.
Sure, we know that, but we need a way to automatically add these restrictions to the thousands of existing tasks so that we don't have to do it manually. Can you help with that?
Sadly, you cannot apply restrictions to the existing issues. Each restriction is tied to both issue type and a project role. From that moment when you set the restriction only those roles will be able to see those issues. So, no, there isn't a way to apply restrictions to existing issues.
That is not true.
You can manually set restrictions on issues in Team Managed projects at any time by clicking on the padlock icon on the individual issue. That assumes that you have the Restrict Issue permission.
Hello @Maciej Oczoś
I'm not sure if it is possible to set issue restrictions on existing Team Managed issues through ScriptRunner.
However if you need to find the name of a field, follow the guidance on this page:
https://support.atlassian.com/cloud-automation/docs/find-the-smart-value-for-a-field/
You may have to call the Jira REST API to make a change to the Security field.
