Where is the list of 'Other Actions' defined in JIRA Cloud? (check attachment).
We had the option to Clone before, now its gone. Its available only after you open the stories individually, which is a waste of time.
Thanks!
the list that you see w/in the context of where you are is the available options. TBH I don't recall what was there before. With that said if you are in the Backlog and click on an issue the righthand sidebar displays the issue and you can click on the ellipses and select many more options including Clone.
Thanks @Jack Brickey - this I knew :) But its an additional click to open the issue first in the sidebar.
We could clone right off the backlog before without going into the issue detail view. Thanks though!
