Hi
Looks like there is no way for managing parallel sprints into next gen Projects. Is it possible to run parallel sprints into a regular project?
Thx in advance!
It is not possible to have parallel sprints in next-gen projects, but it is possible in classic projects.
Go to Jira Settings -> Products -> Jira Software configuration and enable the parallel sprints option.
We would also need the Parallel Sprints to work for next-gen projects. Kindly advise if there's already a plan to deliver this and the timeframe. Thanks
I enabled the parallel sprints option. How do i used it in classic?
