After importing issues from csv file, slas are not showing up. All issues have imported are showing channel: Unknown. I am using JIRA Service Desk project
Can you tell what is the issue? Do i need to add a column sla in the csv file?
Swarna
Swarna,
Does the imported issues trigger the start condition of this SLA rules?
SLA usually start when an issue enters certain status, but also can start after creation.
The issues should trigger the event that causes the sla rule to start
Yes, For example SLAs start when issue is in Status New, but when i import issues using with status status "New". No slas is displayed.
Did you get an answer to this.
This is happening for me as well.
