SQL to return for every project most recent updated date
DI2E Licensing
August 31, 2015
We are hosting > 100 projects in our JIRA instance. I'd like to know if all of these projects are active.
Current idea is to run a query that returns the most recent update date or create date for any issue, one for each project.  So it doesn't matter which issue within the project it is.  I just want to know when the last activity was.
Hope this makes sense. If you have a better way to gather this information would love to hear it.
If it makes a difference, we're running postgresql.
Thanks.
Rodrigo Rosa
September 3, 2015
Hello team,
Please try the query from this previous answer:
https://answers.atlassian.com/questions/176459
I've adapted it to postgres:
SELECT DISTINCT i.PROJECT, MIN(i.UPDATED) as "Last Updated", p.pname
FROM jiraissue i
INNER JOIN project p
ON p.ID = i.PROJECT
GROUP BY i.PROJECT, p.pname
ORDER BY MIN(i.UPDATED) ASC, i.PROJECT, p.pname
DI2E Licensing
September 10, 2015
That is Brilliant!!! Thank you so much.
DI2E Licensing
September 10, 2015
I spoke too soon. :( the results indicated for project ABC that the last update was on 2012-10-16. But when I search on issues for that project, I see updates as recent as 8 days ago. I'll play around with it. I see where you are going here.
DI2E Licensing
September 10, 2015
Okay, changed MIN to MAX and it's a thing of beauty! SELECT DISTINCT i.PROJECT, MAX(i.UPDATED) as "Last Updated", p.pname FROM jiraissue i INNER JOIN project p ON p.ID = i.PROJECT GROUP BY i.PROJECT, p.pname ORDER BY MAX(i.UPDATED) ASC, i.PROJECT, p.pname;
Like # people like this
DI2E Licensing
September 11, 2015
Question ... know what the query would be for confluence and stash??????
hesham raafat
May 28, 2018
do you know how i can get it to list the project keys instead of the project names? or to list both the project keys and names?
German Rodriguez Bolanos December 18, 2018
The Query is working nice! But has a little issue, for nulls values on the "Last issue update" are not listed.
Cody Crandall
DI2E SysAdmin was right max and min needs to be switched for this query to work correctly. Thanks all!
