Goal: I would like to set one field "Acceptance criteria" with different default associated to different issue types, even in the same project.
I see that to do this, we should create new context
the default is:
Then i created a new one, selecting a specific issue type and a project.
But if i want to create a new context to give a different default value to that field for a different issue type, the system "blocks me" (actually, just does not let me configure it) since the project has been already selected in the previous custom context, and it can only be selected once...
Is there a way to reach my goal?
thanks for the answer
This is a useless limitation though...
Do Jira standard field allow multiple context per project instead?
