Sample project for Free plan
Max
Is it possible to add a Sample project (demo project with fake data) to train with the project? Is it possible for Free plan?
It would be great to take the screen on how to add it.
Rebekka Heilmann _viadee_
Hi Max,
I don't think there are sample projects that you can simply add to Jira. The only thing available are project templates, but they don't include data.
The only thing that might work would be a CSV Export/Import for the issues, but you would have to recreate the Project accordingly yourself.
Max
@Rebekka Heilmann _viadee_ here is the answer ^_^
To get the Demo-Sample Project you should click on the "Create Board" menu.
I have just found the info.
Thanks @Max !
Learning new things everyday ;)
Like Max likes this
Max
100% :)
FREE
