I have two questions about the script I am trying to use.
Purpose: I would like to have issuetype = vulnerability tickets to have due dates based on the priority of a ticket when the ticket is created.
If the ticket is blocker , due date +7 days from the creation date
if the ticket is critical, due date +30 days from the creation date
if the ticket is major, due date +90 days from the creation date
1- how can I correct the error message below?
2-how can i add the issuetype of vulnerability to this script since script listener does not have a drop down box for it?
Thanks!
here is the script i used;
import java.sql.Timestamp
// initializing the priority
def CRITICAL = 7;
def MAJOR = 30;
def MINOR = 90;
// calender which returns the date according to the priority defined
private GregorianCalendar getDate(double roll)
Calendar cal = Calendar.getInstance();
cal.setFirstDayOfWeek(Calendar.MONDAY);
cal.set(Calendar.HOUR_OF_DAY,0);
cal.set(Calendar.MINUTE,0);
cal.set(Calendar.SECOND,0);
cal.set(Calendar.MILLISECOND,0);
int numNonBusinessDays = 0;
for (int x=0;x<roll;x++)
if(cal.get(Calendar.DAY_OF_WEEK) == 1 ||
cal.get(Calendar.DAY_OF_WEEK) == 7) {
numNonBusinessDays++;
cal.add(Calendar.DATE, 1);
if(numNonBusinessDays > 0) {
cal.add(Calendar.DATE, numNonBusinessDays);
return cal;
Here is the latest error message after I made the changes you have requested above;
"private GregorianCalendar getDate(double roll){
Well a method of the type "GregorianCalander" can only return a "GregorianCalender" value. The value you are trying to return is only "Calendar" - wont work.
If you are lucky changing:
"private GregorianCalendar getDate(double roll){"
to
"private Calendar getDate(double roll){""
will work but cant garuantee for that.
No error messages however script does not do anything. I created several tickets with Critical, Major and Minor priorities and due date is still empty.
Anyways, thanks a lot for your help.
There are two errors in two lines
Replace with
@Markus ,
which one ;
if(numNonBusinessDays > 0) OR
if(numNonBusinessDays gt > 0)
Either way I have another error message, see below;
