Hi @Harish Tuccapuram ,
you should put in place a behaviour on due date field.
def commentField = getFieldById("comment");
commentField.setRequired(true);
Hope this helps,
Fabio
@Fabio Racobaldo _Catworkx_ Thanks for this.
i just changed only the description on edit view and it's still saying Due date is required even though due date has not been changed.
Can you please help me out.
hey @Harish Tuccapuram , you need to put provided code in due date field and not on initializer. That should be the reason
Ah, i believe I have written on the due date field itself and not on the initializer, I'm I doing something wrong here?
Try this code :
def currentDueDate = underlyingIssue?.dueDate?.dateString def dueDate = getFieldById(getFieldChanged()) def description = getFieldById("description") if ((dueDate.value as Date).dateString != currentDueDate.toString()) { description.setRequired(true) } else { description.setRequired(false) }
Thanks @Fabio Racobaldo _Catworkx_ this code works
else {
commentField.setRequired(false)
however when i try to set an error when due date is changed
commentField.setError("Due Date has changed please enter the comment")
I've already tried a lot of things... Is there a cloud solution for exactly this problem?
Thanks a lot Birgit
