Script Runner Clone Issue and Comment
Aron Felberbaum
I'm looking to use a post function to create a linked issue using script runner, trying to figure out how I could replace the description of the new issue with last comment.
3 votes
JamieA
September 8, 2015
If you are using the "clones issue" built-in post-function, you can enter the following code into the additional issue actions:
def commentManager = ComponentAccessor.getCommentManager()
def comments = commentManager.getComments(sourceIssue)
if (comments) {
    issue.description = comments.last().body
else {
    issue.description = "No comment set on source issue"
Aron Felberbaum
Another Question, This transition is using a screen with the comment field, I would like to replace the description of the linked issue with this comment only when the comment is not empty.
JamieA
September 9, 2015
get the comments in the same way as above but using "issue", not sourceIssue.
JamieA
September 9, 2015
in a transition, the current comment is in: transientVars["comment"] - so if that's empty no comment was added
Hung Nguyen
Jamie,
If I don't want the change the new issue's description, but copy the last comment to be a comment of the cloned one, how can we do it?
I did try to use commentManager.create( issue, comments.last().owner, comments.last().body, true)
But I got the null pointer assignment error in the log and the task failed.
Jens Kisters //SeibertSolutions
October 11, 2017
is the "clone issue" post function still available in the current version?
I can't find it neither in the available post functions nor in the script runner docs.
