Script Runner help needed
Kevin Seery
Have a 'Script Runner' custom field scripted field that I need to delete. Can find out how to do this?
Also how do you change a name of 'Script Runner' custom field scripted field, change the name in JIRA but does not show up in script runner list of custom fields?
Many Thanks
Kevin
Mark Markov
July 17, 2018
Hello @Kevin Seery
Add-ons -> Script Fields -> your scripted field -> Actions -> Delete
This will also delete it from your custom fields section.
To rename field go to Custom Fields -> Your custom field -> Edit
Kevin Seery
Thanks Mark,
just to simple, was over thinking this....
