I use this article to restrict resolutions by IssueType using Behaviour, but it doesn't work.
I change my parametres as the code bellow and when I do a test, still appear all resolutions,.
my script:
import static com.atlassian.jira.issue.IssueFieldConstants.Resolution
if (getActionName() == "Close Issue") {
def constantsManager = ComponentAccessor.constantsManager
def allowedResolutions = constantsManager.resolutions.findAll {
it.name in ["Duplicated"]
getFieldById("Resolution").setFieldOptions(allowedResolutions)
Have you tried with getFieldById("resolution")? System field ids are generally all lowercase.
Or, correct your import and use the correct RESOLUTION (without quotes)
import static com.atlassian.jira.issue.IssueFieldConstants.RESOLUTION
getFieldById(RESOLUTION).setFieldOptions()
Hello Peter,
Thanks for your reply.
I already tried that, but it didn't worked.
I'm having some problems with behaviour scripts that it's working in another instances and in this partilary it's not for some reason.
I think maybe the problem is with my version.
Jira: 7.6.1
ScriptRunner: 5.2.2
Then the next step is to output some logs.
Also, you have to convert your allowedResolutions into a Map object
log.debug "Behavior Test - actionName= ${getActionName()}"
log.debug "Behavior Test - allowedResolutions = $allowedResolutions"
def resolutionMap = allowedResolutions.collectEntries{[(it.id ): it.name
log.debug "Behavior Test - resolutionMap = $resolutionMap"
getFieldById("resolution").setFieldOptions(resolutionMap)
