Script help
Spruha Shah October 12, 2023
I want to get a list of all active users with username and email address from a specific group in jira.  Trying to run this scirpt through script Runner console, any suggestions on how to get email address too? i pulled a list with just usernames.
Stefan Salzl
Hi @Spruha Shah
could you share your code? This would make it easier to analyze the problem.
How do you get the user names? do you only get a list of strings with the names or do you get a list of user objects?
Generally the user object has an email property and you can get this from a user object variable eg. ‚user‘ as follows:
user.getEmailAddress()
Best
Stefan
Spruha Shah October 18, 2023
def groupManager = ComponentAccessor.getGroupManager()
def user = User.getEmailAddress()
String groupName = "jira-software-users"
groupManager.getUsersInGroup(groupName)
user.getEmailAddress(user)
i am trying to get all users that are in 'jira-software-users' not just with username but also with email.
In our jira, username and email are different for each user.
Stefan Salzl
Returns a collection of user objects of the users in the group. If you add a .getEmailAdress() it will return the email of all users.
The following script should do the work:
groupManager.getUsersInGroup(groupName).getEmailAddress()
Best
Stefan
SERVER
