Script to transition issue during create workflow instead of fast-track
T0pH0ur
Ive made a POC where we have an issue type and sub-tasks. The design is that when a new Event is logged we will have the subtasks auto-generated for the event manager.
Based on a select list choice, the issue transitions from Open to In-Progress and generates a specific set of subtasks.
The setup is working perfectly to create the subtasks on transition and with the POC using the ScriptRunner "Fast Track transition an issue" post function after the create event in the create transtion it worked as intended
I need to have 32 different transitions, so a bit of a pain to build with fast-track post functions and maintain, so i wrote a script.
Placing the script after the event, yields nothing, yet there are no errors in script. Im hoping Im just missing something small
here is the simplified version, thanks for any assistance:
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.customfields.option.Option
//field id
long fieldId = 13847L;
//map of Select list value to Transition ID
Map typeMap = [
"List Option 1": 151,
"List Option 2": 81,
"List Option 3": 61
def customFieldManager = ComponentAccessor.getCustomFieldManager();
CustomField field = customFieldManager.getCustomFieldObject(fieldId);
Option fieldOpt = issue.getCustomFieldValue(field) as Option;
def fieldVal = fieldOpt.getValue() as String;
def transitionID = typeMap[fieldVal];
issue.transition(transitionID);
Sergei Troshin
March 27, 2025
Hi @T0pH0ur hope you're doing well!
I'm familiar with this HAPI issue, but I’m not sure why it’s not working, as I can’t see the source code. Let me share the code I use for such cases:
import groovy.transform.Field
import com.atlassian.jira.util.ErrorCollection
import com.atlassian.jira.workflow.TransitionOptions
import com.atlassian.jira.workflow.IssueWorkflowManager
import com.atlassian.jira.workflow.WorkflowTransitionUtil
import com.atlassian.jira.workflow.WorkflowTransitionUtilFactory
@Field final IssueWorkflowManager issueWorkflowManager = ComponentAccessor.getComponent(IssueWorkflowManager.class)
@Field final WorkflowTransitionUtilFactory workflowTransitionUtilFactory = ComponentAccessor.getComponent(WorkflowTransitionUtilFactory.class)
@Field final long SELECT_LIST_CF_ID = 10400
@Field final Map<String, Integer> OPTIONS_AND_TRANSITIONS_MAP = [
    "Option #1": 11,
    "Option #2": 21,
    "CustomOption #3": 31
MutableIssue issue = (MutableIssue) issue
CustomField optionField = ComponentAccessor.customFieldManager.getCustomFieldObject(SELECT_LIST_CF_ID)
Option option = issue.getCustomFieldValue(optionField) as Option
if (Objects.isNull(option)) {
    log.warn("Option field is empty")
    return
String optionValue = option.getValue()
Integer transitionId = OPTIONS_AND_TRANSITIONS_MAP.get(optionValue)
if (Objects.isNull(transitionId)) {
    log.warn("No mapping for $optionValue option")
    return
doTransition(issue, transitionId, Users.getByName("jirabot"), true)
boolean doTransition(MutableIssue mutableIssue, int actionId, ApplicationUser user, boolean skipRestrictions) {
    TransitionOptions.Builder builder = new TransitionOptions.Builder();
    TransitionOptions transitionOptions =
        skipRestrictions
            ? builder.skipConditions().skipPermissions().skipValidators().build()
            : builder.build()
    if (!issueWorkflowManager.isValidAction(mutableIssue, actionId, transitionOptions, user)) {
        return false
    WorkflowTransitionUtil workflowTransitionUtil = workflowTransitionUtilFactory.create()
    workflowTransitionUtil.setAction(actionId)
    workflowTransitionUtil.setIssue(mutableIssue)
    workflowTransitionUtil.setUserkey(user.getKey())
    Map<String, ErrorCollection> errors = new HashMap<>();
    errors.put("validate", workflowTransitionUtil.validate());
    boolean result = !errors.get("validate").hasAnyErrors();
    errors.put("progress", workflowTransitionUtil.progress());
    if (errors.get("progress").hasAnyErrors()) {
        result = false;
    return result;
Here is also this code in GitHub
Important! I've tested this code in my test environment, but I strongly recommend that you test it again in your own environment.
Sergei Troshin
March 27, 2025
Ooh, i forgot mention that you have to put this script at the end of post-functions:
T0pH0ur
Hey @Sergei Troshin
Thanks for this. Ive added the script to the end of the post function stack as the other was before, swapping out my map values and adding in some debug to see where it might fail.
It still errors out when attempting to call the function to handle the transition. I notice on your screenshot it seems this is not in the create transition. While the normal fast track post function works there, im curious if an issue here for it?
Sergei Troshin
March 28, 2025
Oh, sorry, I misunderstood—you need to put this on the Create transition.
In this case, we first need to change OSWorkflowEntry from Created to Activated before performing the Fast-track action.
Here is complete script:
import org.ofbiz.core.entity.GenericValue
import com.atlassian.jira.ofbiz.OfBizDelegator
import com.opensymphony.workflow.spi.WorkflowEntry
    "Option #1": 11,
    "Option #2": 21,
    return
    return
    final OfBizDelegator ofBizDelegator = ComponentAccessor.getOfBizDelegator()
    GenericValue gv = ofBizDelegator.findByPrimaryKey("OSWorkflowEntry", mutableIssue.getWorkflowId());
    if (Objects.isNull(gv)) {
        log.warn("gv is null")
        return
    if ((Integer) gv.get("state") == WorkflowEntry.CREATED) {
        gv.set("state", WorkflowEntry.ACTIVATED)
        gv.store()
        skipRestrictions
            : builder.build()
        return false
        result = false;
    return result;
T0pH0ur
hey again @Sergei Troshin ,
Thanks so much for the follow-up. This morning when i came in, before this was posted, I thought about how previously using fast track works from create, so my workaround was simply to add a status inline using the existing fast-track plugin on the create and then actually my script that I started the question off worked perfectly
I accepted your answer as this will hopefully provide others with two options should they run into the same situation and find this.
Cheers!
Topher
Sergei Troshin
March 27, 2025
Here was accidently duplicated message
Dick
Hi @T0pH0ur
I'm not familiar with scriptrunner, but you should start by logging the in-between results and proof that a certain piece of script has been executed.
This post can help you realize this.
Dick
T0pH0ur
hey @Dick thanks
So the script fails entirely at the end here:
My last log before shows it makes it to get the tansition ID(note this is on the full length with many more transitions and 51 is a valid transition):
"Made it to final step with transition ID as 51"
Do you know if ther is an issue to transition using the ID?
