ScriptRunner examples doesn't work in Jira
KL Kumar
I’m using Jira Data Center (v9.15.2) and attempting to run the basic ScriptRunner examples provided under "Example Scripts," specifically the "Show Web Panel" script highlighted in yellow. However, the script doesn’t seem to compile and consistently displays "Checking script" at the bottom right.
The current ScriptRunner version I’m using is 8.34.0.
Could anyone let me know if they’ve encountered this issue?
Thank you!
Ram Kumar Aravindakshan _Adaptavist_
Hi @KL Kumar
Could you provide a full screenshot of your Fragment configuration? This is to double-check if the correct fragment is being used.
Thank you and Kind regards,
Ram
KL Kumar
Matt Doar _Adaptavist_
That's odd. Do any other of the example scripts or other parts of ScriptRunner work for you?
KL Kumar
Hello Matt,
The issue seems to be when using the HTML and/or JavaScript examples in ScriptRunner. The other Groovy scripts seems okay.
Tried the below, but no luck yet!
SERVER
VERSION
9.15.2
