Scriptrunner Behaviour not to run on Create Issue screen
Martin Haagen
October 18, 2017
Use case: The customer wants a number of fields set to read-only when issues have certain statuses.
My solution: I have created a Scriptrunner Behaviour with an Initialiser script as follows:
if (getAction()?.id == 1) { //Do not run script on Create action
  log.warn('ACTION = CREATE')
  return
def lockStatuses = ['status1','status2','status3'] //Statuses where fields should be read-only
def issueStatus = underlyingIssue.status.name.toLowerCase() //Status of the undelying issue
if (!lockStatuses.contains(issueStatus)) {
  log.warn('STATUS WILL NOT MAKE FIELDS READ-ONLY')
  return
else {
  log.warn('SETTING FIELDS READ-ONLY!')
  def lockFields = ['customField1','customField2','customField3'] //Fields that should be set to read-only
  lockFields.each { lockField ->
    getFieldByName(lockField).setReadOnly(true)
  getFieldById("summary").setReadOnly(true)
This works fine on Edit- and Transition screens.
My problem: If I first view an issue that has one of the above statuses, and then press the "Create" button, the above fields is being set to read only on the Create screen, despite the first "if" in the script.
If I Cancel out of the Create screen and press the "Create" button once again, the fields are now writable. The issue seems to only occur directly after opening av issue, or after previewing it on boards.
Do anyone have suggestions on what I should try next?
3 votes
Stephen Cheesley [Adaptavist]
October 23, 2017
Hi Martin,
Try switching out your first if statement for the following:
if (getActionName() in ["Create Issue", "Create"]) {
return
 I've found when doing this you need to take into account "Create" and "Create Issue"
Hope this helps!
Steve
gabe vid May 16, 2019
That works in a initializer, but not in a server-side script.
Is there a way to do that in server-side script ?
