Scriptrunner - How to Link an Issue when a Jira Issue is mentioned in a comment
Nick September 20, 2018
Looking for a way to automatically link any issue that is mentioned in a comment, in any thread across all projects.
E.g. User 5 comments on a Jira Issue with a link to Jira Issue 101A
Issue 101A is then linked from the original Issue
Orkun Gedik
September 20, 2018
Hello @Nick,
You can use script listener with MentionIssueCommentEvent. Let me know if you need more detail or help.
Orkun Gedik
Thanks Orkun, and what code in the inline script part to add it as a Link?
Orkun Gedik
September 20, 2018
You are welcome @Nick.
You can use the following line to create link between issues.
ComponentAccessor.getIssueLinkManager().createIssueLink(Long sourceIssueId, Long destinationIssueId, Long issueLinkTypeId, Long sequence, ApplicationUser remoteUser)
Source issue and destination issue are depends on how you want to link issues.
Thank you - what do you mean by "Source issue and destination issue are depends on how you want to link issues.
Simply want a "relates to" link between Issues
Apparently "ApplicationUser" in the above cannot be resolved
Orkun Gedik
September 20, 2018
What I meant is you can define your source issue and destination issue how link direction you want. Also what version of Jira you are using? If you are using version 6.X, you have to use "com.atlassian.crowd.embedded.api.User" instead of ApplicationUser. "user.getDirectoryUser()" returns the paramater you need.
Latest version
I think it's "remoteuser" it doesn't like
Orkun Gedik
September 20, 2018
It must be ApplicationUser. You can check it out here.
Hm, if I ignore the error and submit anyway, it doesn't run. "unable to resolve class ApplicationUser"
Orkun Gedik
September 20, 2018
You need to import ApplicationUser. Add the following line in your script.
Thanks so total script is
I checked in ScriptRunner and it provides this error
The variable ComponentAccessor is undeclared
Nick September 21, 2018
@Orkun Gedik @Tarun Sapra this is amazing functionality when it's working, any ideas why the above would fail?
Thanks so much.
Tarun Sapra
Hello @Nick
You have to import the component accessor class as well
https://docs.atlassian.com/software/jira/docs/api/7.6.1/com/atlassian/jira/component/ComponentAccessor.html
Add this in your code in starting of the class
Thanks, now it's
It shows a [Static type checking] Cannot find matching method
But I assume it will work anyway?
Orkun Gedik
September 24, 2018
You may ignore that error, I assume it works. But the paramater that you are passing in createIssueLink() method is not initiliazed in your code (If you shared all script above).
Nick September 24, 2018
Thanks @Orkun so if I may ask what would be the final code for the script?
Much appreciated
Nick September 27, 2018
@Orkun Gedik @Tarun Sapra I wasn't able to get the able code working in its current form - as experienced Scriptrunner gurus would you happen to know what remains to be tweaked?
Nick October 3, 2018
I wanted to mark this one as Done as I thought it would be really useful for others, the current script is failing when it runs based off the code above, what is missing?
Tarun Sapra
Hello @Nick
Can you please paste the complete code which you are using currently in your instance.
Hey @Tarun Sapra
Code is:
Nick October 10, 2018
@Tarun Sapra any ideas?
Nick October 20, 2018
Any @Tarun Sapra @Orkun Gedik any ideas so we can close this?
Tarun Sapra
Hello @Nick
The approach suggested by @Orkun Gedik is useful for newly added issues in comments, but not if you want to link issues which are already added in the comments. Because the listener will be triggered based on the event MentionIssueCommentEvent only for new scenarios and not for existing tickets if you wish to link them.
Thanks Tarun
