Hi @Cedacri
Please clarify: Why do you need to use a Web Panel for the Transition screen when it can be customized to display the fields you intend to use in it?
I am looking forward to your feedback.
Thank you and Kind regards,
Ram
I need to add some kind of static warning for the user in the screen header/footer before he/she updates the status. Showing a web panel meets the requirements.
On a side note, do you know perhaps how it could be implemented with
Hi @Cedacri
Web Panels cannot be used in the Transition screen.
Instead, you can use Behaviour to add an Error message if a user, for example, enters or selects an invalid value.
Let me know if this suits your requirement.
Ram
@Ram Kumar Aravindakshan _Adaptavist_ As you can see bellow, I did manage to use it in the Transition screen:
which is where the Info banner was placed, this solution is wonky at best since it is in the middle of the comment field and cannot be changed to another location.
As said initially, I need a static warning that always will be present in the transition screen, no matter the correctness of the user input - hence my web panel solution.
I do wonder if there is a better way to do it.
