Scriptrunner - Post Function - Clone and Issue, and links
Nicolás Figueroa
Im creating 5 automatic Issuelinks with a PostFunction Scriptunner (Clone and Issue, and links) with that everythink is okey, the problem is I want to perform a "Aditional issue action" where (here is de difficult part) Want to copy a value from the Main Issue, but this customfield(text field single line) have a formated input like (CODE=VALUE;CODE=VALUE;...), in the linked issues need to sum each VALUE and then assign 20% of the sum in each issuelink.
Not sure if you this is posible from there, maybe other kind of function can resolve this.
mogavenasan
January 13, 2021
Hi @Nicolás Figueroa,
I hope that my understanding is correct:
  1. Parent issue will have a custom field with value as per the following; CODE=VALUE;CODE=VALUE;...
  2. For the issues that we are automating the creation, we would like to process the string and assign 20% of the sum to each linked issues.
  3. So basically what the code needs to do is to get the content of the field, sum all the VALUE and then assign 20% of the sum to each linked issue.
  4. The custom field is the same for the parent and child issues.
Correct me if I'm getting anything wrong here. If I got it all right, then this should be script:
def cf = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'custom field name'}
def cfValues = sourceIssue.getCustomFieldValue(cf)
def cfValue = cfValues.split(';')
float value
for ( String item : cfValue ) {
value = item.split('=')[1]
value += value
def finalValue = value * 0.2
issue.setCustomFieldValue(cf, finalValue)
FYI, I didn't test the script. I hope that this helps.
Moga
Nicolás Figueroa
Hello @mogavenasan
Thanks for your quick response and yes you are undestading well the case.
I try the script and change the value for String because its give error (cause float value = String item) and then convert it a float, but im not sure if im doing it well.
Also the script gives this error:
Nicolás Figueroa
Updated: now have no error, but the field its not updated:
def cfValues = sourceIssue.getCustomFieldValue(cf) as String
float values
def value = item.split('=')[1]
values = value as Float
values += (float) values
def finalValue = values * 0.2
Nicolás Figueroa
After some modification I can make it run:
def cf = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'Custom FieldName'}
def cfValue = sourceIssue.getCustomFieldValue(cf)
//Use string array to hold all values and convert them to String
String[] cfValues = cfValue.toString().split(';')
double values = 0.0
for ( String item : cfValues ) {
//Convert the VALUES to duble
Double value = Double.parseDouble(item.split("=")[1])
values += value
//Convert to string because the customfield is SimpleText
def finalValue = String.valueOf(values * 0.2)
Like mogavenasan likes this
Teja
June 2, 2021
You have mentioned "Im creating 5 automatic Issuelinks with a PostFunction Scriptunner (Clone and Issue, and links)", How have you been creating 5 issue links with the single post-function? or you have used 5 post-function.
Nicolás Figueroa
Hello @Teja
I have created 5 different post-functions with Scriptrunner.
Maybe you can create only 1 post-function that create 5 issuelinks but I believe you need to write some code.
Teja
June 3, 2021
@Nicolás Figueroa
Ok sure, thanks
