Scriptrunner Post Function - Sets Component based on Single List Custom Field
Matt Bausher February 12, 2019
I am trying to have a post-function that sets the component based off of a required Single List custom field (Ex: selecting the DEB option sets the component to Machien Shop - DEB).  However, when executed the custom scriptrunner script fails stating the value is null.
I've tried referencing other similar topics but wasn't able to find the obvious answer.
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption
//a map with single list options to associated component
def componentsMap = [
"DEB" : "Machine Shop - DEB",
"GR" : "Machine Shop - GR",
"LC" : "Machine Shop - LC",
"LM" : "Machine Shop - LM",
"MC" : "Machine Shop - MC",
"MCP" : "Machine Shop - MCP",
"MCX" : "Machine Shop - MCX",
"MM" : "Machine Shop - MM",
"MXP" : "Machine Shop - MXP",
def issue
issue = issue as MutableIssue
def selectList = customFieldManager.getCustomFieldObject("customfield_14161")
//Catches if the field does not exist
if (! selectList) {
return
def selectListValue = issue.getCustomFieldValue(selectList) as LazyLoadedOption
//Catches if there is no value for the select list
if (! selectListValue) {
return
def componentManager = ComponentAccessor.projectComponentManager
def componentName = componentsMap.get(selectListValue.value)
def component = componentManager.findByComponentName(issue.projectObject.id, componentName)
if (component) {
componentManager.updateIssueProjectComponents(issue, [component])
 The script doesn't show any errors until I run a test issue and it produces the following.
The following log information was produced by this execution. Use statements like:log.info("...") to record logging information.
2019-02-12 07:47:53,807 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2019-02-12 07:47:53,807 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: PRD-14901, actionId: 1, file: <inline script>
java.lang.NullPointerException: Cannot invoke method getCustomFieldValue() on null object
	at Script78.run(Script78.groovy:28)
Alejandro Suárez García
Hi again @Matt Bausher,
I tested this scripted postfunction (changed back to your customfield ID) and it works fine for me. The only two requirements are:
  • To have a Custom Field with that options - DEB, GR, LC... etc
  • To have the Components created in the project you want.
Here is the code (put it in the first postfunction place)
import com.atlassian.jira.bc.project.component.ProjectComponent
import com.atlassian.jira.bc.project.component.ProjectComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.customfields.option.Option
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
ProjectComponentManager componentManager = ComponentAccessor.projectComponentManager
"DEB": "Machine Shop - DEB",
"MCP": "Machine Shop - MCP",
"MCX": "Machine Shop - MCX",
"MXP": "Machine Shop - MXP",
CustomField selectList = customFieldManager.getCustomFieldObject(14161L)
Option selectListValue = issue.getCustomFieldValue(selectList) as Option
if (selectListValue) {
String componentName = componentsMap.get(selectListValue.getValue())
ProjectComponent component = componentManager.findByComponentName(issue.projectObject.getId(), componentName)
if (component) issue.setComponent([component])
You can also ignore that map, and just use the following code:
String componentName = "Machine Shop - " + selectListValue.getValue()
Like Matt Bausher likes this
Hello @Alejandro Suárez García,
Both of the options you listed above worked out perfectly for me and I personally prefer the option without the map.
Thank you for taking a moment to help me out!
Matt Bausher
Hi @Matt Bausher the error says that the CustomField don't have any value when you execute the script. Let me do a few tests and I give you an answer.
