I have a transition that creates a bunch of sub tasks. when a particular subtask is created, I want to create a link issue using the "Clones an issue, and links [ScriptRunner]" post function. Under the condition section, I have this:
issue.summary.matches("MM conducts Table 3 Training(.*)") && issue.issueType.name == "PCT Sub-Task"
this works fine when I tested it with additional issue actions and set the summary to below
issue.summary = 'Test'
Now, I have a custom field that I want to copy from the parent task that triggered the subtask and this linked task, so I created the script below
Issue parentIssue = issue.getParentObject()
def proj = ComponentAccessor.getProjectManager().getProjectByCurrentKey("PCT").id
def pct = parentIssue.issueType.name as String
def cfMgr = ComponentAccessor.getCustomFieldManager()
def newCHAOCf = cfMgr.getCustomFieldObjects(proj, pct).find {it.name == 'New CH/AO'}
def newCHAO = parentIssue.getCustomFieldValue(newCHAOCf) as ApplicationUser
MutableIssue mm_task = ComponentAccessor.getIssueFactory().getIssue()
mm_task.summary = ('Conduct ILT for New CH/AO' + ' [' + newCHAO.getDisplayName() + ']') as String
I am getting the error below:
java.lang.NullPointerException: Cannot get property 'issueType' on null object
it seems like it is not getting the parent issue object properly. Any input would be much apprecaited. Thank you.
Update: the code below is what ended up working for me:
def cf = customFieldManager.getCustomFieldObjects(sourceIssue).find {it.name == 'New CH/AO'}
def ch_ao_val = sourceIssue.getCustomFieldValue(cf) as ApplicationUser
def summary = ('Conduct ILT for New CH/AO' + ' [' + ch_ao_val.getDisplayName() + ']') as String
def description = ('MM Team, AE roles submitted on' + ' [' + ch_ao_val.getDisplayName() + ']') as String
issue.summary = summary
issue.description = description
I am not sure why issue.summary = 'some string' works but
Hi @Lisbon Cruz
For your requirement, you must first validate whether the current issue is a Sub-task. This is missing in your code, which is why it is failing.
Below is a sample working code for your reference:-
import com.atlassian.jira.event.type.EventDispatchOption
def issueManager = ComponentAccessor.issueManager
def loggedInUser = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def customFieldManager = ComponentAccessor.customFieldManager
def sampleTextField = customFieldManager.getCustomFieldObjectsByName('Sample Text Field').first()
if (issue.isSubTask()) {
def parent = issue.parentObject
def parentFieldValue = parent.getCustomFieldValue(sampleTextField) as String
issue.setCustomFieldValue(sampleTextField, parentFieldValue)
issueManager.updateIssue(loggedInUser, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
Please note that the sample code above is not 100% exact to your environment. Hence, you will need to make the required modifications.
if (issue.subTask) {
issue.set {
setCustomFieldValue('Sample Text Field', parent.getCustomFieldValue('Sample Text Field'))
Below is a screenshot of the configuration using HAPI:-
I hope this helps to answer your question. :-)
Thank you and Kind regards,
Ram
Good Morning,
It looks like I do have scriptrunner 8.7.0. Do I have to add the custom script post function in addition to clones issues? Here is my current configuration:
Would I have to add the "HAPI" Script above in addition? Also, the reason I am doing it this way, rather than just using project automation is to be able to grab the custom field value of the "users" custom field.
I tried the first code and it worked. But I need to set the summary and description to something custom, hence why I am using scriptrunner. Here's the code that I have:
def issuemgr = ComponentAccessor.issueManager
def log_in_usr = ComponentAccessor.jiraAuthenticationContext.loggedInUser
def cus_field_mgr = ComponentAccessor.customFieldManager
def new_ch_ao = customFieldManager.getCustomFieldObjectsByName('New CH/AO').first()
def ch_ao_val = parent.getCustomFieldValue(new_ch_ao) as String
issue.setCustomFieldValue(new_ch_ao, ch_ao_val)
issue.setDescription('MM Team, AE roles submitted on' + ' [' + ch_ao_val + ']') as String
issue.setSummary('Conduct ILT for New CH/AO' + ' [' + ch_ao_val + ']') as String
issuemgr.updateIssue(log_in_usr, issue, EventDispatchOption.DO_NOT_DISPATCH, false)
I just put this under the "Additional issue actions" in "Clones an issue, and links [ScriptRunner]" post function. I am getting the subtasks summary, despite setting the summary to something custom.
